how works data high way
jim-garcia
Oct 2003
Reynosa
42
hello can anybody
give a little information how works data high way comunication
what type of interface , configuration we have a new proyect and we want to use it or if is better use device net
we are going to use slc 5/04 procesor
thank you for your time
jim-garcia said:
have a new proyect and we want to use it (DH+) or if is better use device net
You are basically comparing apples to oranges. DeviceNet could be a lot better, or DH+ could be a lot better depending on the application.
What are you planning to do with your network?
If for example, I/O or connection to VFD's, Devicenet would be better - messaging between other PLC/SLC's and connecting to HMI's, DH+ would be better.
use of data high way
basically I don't have any experience with data high way
and on my new job they are using it with a 5/04 cpu
any help woul be great
thank you !!!!
Does anyone know if the following is possible? Using an S7-1215 or S7-1217 cpu, can I read data from two different networks and then in the...
1,744
We are working on a machine that has a Yaskawa controller (MP2300siec) and servos. We were provided a copy of the source code and went ahead...
2,561
Can anyone help me to store String data(eg: mobile number) into Device Batch memory? I dont know which application instruction should i use? i...
3,217
Hello, I would like to know the best way to find the source of data in a holding register. I am using Proworx NXT with various Modicon PLCs...
1,849
Is it possible to import trend data into an existing project? I have previous trend data and would like to import it into the current project.
2,023
