Tracing Data in Modicon Networks
MetAldaMan
Jul 2013
Syracuse, NY, USA
Hello,
I would like to know the best way to find the source of data in a holding register. I am using Proworx NXT with various Modicon PLCs.
Example:
I find a register, 4xxxx1, being used in a program. A search for this register shows no other locations for it aside from the place where I saw it within the specific PLC that I am working on.
It is my understanding that a MSTR command in another PLC on the network can access and write to any registers it wants to in any plc on the network, aside from protected registers. Please correct me if I'm wrong.
Considering that I believe the previous statement to be true, I am under the impression that I would have to search every MSTR command on every PLC on the network to find every possible instance where my original 4xxxx1 register could be being altered.
I really hope I'm wrong about that. I want to know the best way(s) to find the source of communicated data in a modicon PLC program. Please advise.
Thanks!
You're correct.
I've done analysis of interconnected systems like this and it's a big effort both in analyzing the network and in reviewing the programs.
The biggest challenge is when the MSTR commands are not cyclic or repeating; if they happen on an event, or on a startup, you're not necessarily going to catch them with a protocol analyzer.
I have registers changing on a PLC-5 and I don't know the source. This was harmless until I tried to use them and found they are being zeroed even...
3,553
Hi, we have a plant that runs with a GE Fanuc 90-30 and I am trying to trace what is triggering a 'General Fault' alarm to the site SCADA system...
2,645
Hello friends, I've an liquids impurities detector connected to a computer. A problem occurred when start the application software, an error...
1,662
Hi everyone.. Can anybody help me, My Simatic Step7 cannot tracing address using right click on I/O address using "Go To Location". If i do it the...
6,455
Hello, Is there a more simple method to trace a PLC code (Siemens S7) other than doing a cross reference on every marker? I'm trying to find out...
2,451
