tracing fail
johneedw
Oct 2009
asia
204
Hello friends,
I've an liquids impurities detector connected to a computer.
A problem occurred when start the application software, an error message appears as shown in the attachment !..
I can't determine if the problem with the instrument or with the software via this message!..
Help me please to diagnosis the fault.
Note, I've removed its program and reinstalled it but the problem remain the same !
That's an error message coming from the operative system. The program is crashing and Windows (?) is giving information about the methods/functions of the program where the problem was detected.
Did you edit it the program? Did you update the operative system?
The message is not from Windows. It's from the OEMs software package running on the PC.
Sometimes software is written with little to no diagnostics. Check the communications connection. If RS232, do you have the correct port configured on the PC? If you're using a USB-RS232 converter, did you plug it into a different USB port?
Hi, we have a plant that runs with a GE Fanuc 90-30 and I am trying to trace what is triggering a 'General Fault' alarm to the site SCADA system...
2,648
I have registers changing on a PLC-5 and I don't know the source. This was harmless until I tried to use them and found they are being zeroed even...
3,570
Hi everyone.. Can anybody help me, My Simatic Step7 cannot tracing address using right click on I/O address using "Go To Location". If i do it the...
6,458
Hello, I would like to know the best way to find the source of data in a holding register. I am using Proworx NXT with various Modicon PLCs...
1,851
Hello, Is there a more simple method to trace a PLC code (Siemens S7) other than doing a cross reference on every marker? I'm trying to find out...
2,454
