Resistive Heating element:
Spec = 240VAC 1200 Watts.
Amps calculates to 5 AMPS.
If the same load was powered by a 208VAC source, AMPS would calculate to 5.7 AMPS.
Question is, is the WATTS rating printed on the label a constant? In other words, regardless of the voltage applied, we should be using MFG's WATTS rating to calculate current draw based on the supply voltage. Trying to understand how "WATTS" remains a constant in this scenario un-affected by V or I.
Cheers.
Cheers.
