Analog Resistive Sensors - 150/300/600 Ohm
Jieve
Feb 2012
USA
274
Hello,
A number of the Siemens analog input modules for the S7-300 (and I assume 1200, 1500) have options for selecting 150, 300 or 600 Ohm resistance sensors, that function similar to the PT100 type RTD's (potentiometers would probably also fall under this category). I have been searching but have not come across any sensors with this behavior (process value between 0 and 150 Ohms, for example). Does anyone know what these type of inputs are commonly used for? Are these certain types of RTDs or are they designed for specific potentiometer inputs or something?
Thanks!
150 ohms is about 150 celsius on a Pt100
so the scale runs from -200 to 150
they just get the resistance from the voltage input with a current of 1 mA
and then calculte the Celsius.
very common and simple to make.
Hi all. I have 1793-IE4 (4)analog inputs modules in a 1794-ADN IOFlex DeviceNet Rack. I cannot find if I can I have access to individual channel...
33
Good afternoon, I am currently working with an HMI/PLC LP-a070 and I require at least one analog output, but the PLC does not have one. I was...
121
Hi all. Customer wants analog faceplates really bad, even if we explained that it doesn't make much sense in his process. What he wants to see...
134
I'm having trouble calming down 2 Tempo Sonics. I'm using Studio 5000 CompactLogix my Raw value is jumping around from 8575.0 to 8755.0 at a...
30
1,178
I cannot add SLC500 analog input tag (I: 8.3) to EZSeries Touch Panel Editor (V 5.3). I used all the listed tag datatype but it all says "Invalid...
283
