Button Configuration in Protool
godfrey
Apr 2002
Charlotte, NC
412
I'm configuring a button in Protool to toggle a bit in the processor on and off. I noticed that while I can configure the color of the button to change with the state change, i can't seem to change what the text on the button displays. I want the button to display "ON" when it is pressed and the bit is set and "OFF" when the button is pressed again and the bit is reset. I'm using Protool/Pro CS V6.0. Any ideas?
Instead of displaying static text on the button you can select a text list. Create a text list with 2 values 0=Off, 1=On and use the bit you're toggling as the index tag for the text list.
Hello, I'm using FactoryTalk View ME V10. I created a valve as a global object with multiple parameters and when the object is being used at the...
130
FactoryTalk View ME running on PanelView Plus 7, connected to Compact GuardLogix 5380 PLC Customer is asking for a physical push button to be...
181
Hi everyone Is it possible to change a button image in FactoryTalk View SE (v13.00) using VBA?
82
I was looking for this function, so that i doesn´t need to do it in the PLC. If there are an alarm in the alarm list, i want to flash the...
528
Hi, I'm just looking for a simple way to make a button in excel (via VBA I presume) to toggle a bit in RSLogix 5000. I just got FactoyTalkLinx...
546
