Connecting between Beckhoff BX9000 and TwinCat 2.1
daiphongsk
Jul 2014
Viet Nam
I am newbie in using the Twincat software.
I have tried to connect between Beckhoff BX9000 and Twincat. But I was not successful.
In the Twincat system manager, I want to add route with BX9000, but i don't know user name and password to log on. You can see that issue in the attached picture.
I installed Twincat 2.1 on window 7 ultimate.
Please tell me what the user name and password are. And do you have any manuals or instructions for using the TwinCat. Please send them to me.
I appreciate your supports.
I just connected between TwinCAT and Beckhoff BX9000 successfully
The procedure is below:
- The IP address of BX9000 usually is 172.16.17.21 with the sub-net mask 255.255.0.0
- Set your PC to the same network class, for instance 172.16.21.2 (sub-net mask 255.255.0.0).
- The name of BX9000 is BX_160037 (You can see on the label of the BX9000, the MAC-ID is 00-01-05-16-00-37, and the name is BX_160037).
- Now use PING to test whether a connection exists, Ping BX_160037.
- Now start the TwinCAT System Manager and search for the BX9000 via Ethernet
- The user name and password are blank, just click Ok.
By the way, i'm a newbie of this 4r. I hope that we can help each other.
Hi I have two PLC AB compactlogix 1769-l16er-bb1b on the same location i need to read level sensor on the other PLC I know each one IP address...
1,299
I was trying to connect between Twincat 3 to RT Toolbox 2 via TCP/IP, I want to try using the sample program from beckhoff Here is the link to...
1,861
Hello everyone! At present, I have 2 PLCs S7200 and 2 HMIs TP170. I want to connect them together. However, I don't know how do I do? May I have...
2,852
Hi, does anyone know of a way of communicating between a Omron CJ1M PLC and a Westermo GS-01 modem?
6,166
Good Day to all of you, this is my first post, i will try to explain as best as possible, english is not my natural language. I am performing an...
36
