Sending data from DSE 8610 Power sharing Module to PC
IdealDan
May 2017
MA
480
Hi Friends,
I want to Integrate data from a DSE 8610 Power sharing Module onto a PC via Modbus.
Which amongst the two methods below is better?
1. to take data to PLC first via Modbus, then integrate from PLC to PC
2. From DSE 8610 Energy Module straight to SCADA?
Thanks in advance.
This will depend on your application. If the information in the DSE 8610 is need in the PLC then use the PLC to pole the DSE 8610.
If information is not required for the PLC to operate, I would then go directly into the PC.
Regards,
Regards,
Thanks for responding,
If I can pull straight to PC, there is no other need for PLC.
MY QUESTION WILL BE:
Which software can achieve this for me without additional Module? OR do I need a modbus card for this?
It looks like the DSE 8610 can communicate Modbus RTU (Serial RS232 or RS485) or Modbus TCP (Ethernet)
I would look at Modbus TCP with the PC running a program like AdvancedHMI.
https://sourceforge.net/projects/advancedhmi/
This is free software that will run in visual studio. It is opened source and is written in VB.net.
Hope this helps you out.
Regards,
Regards,
It Has Modbus RTU, no Modbus TCP,
Can AdvancedHMI work in this regard?
If YES, is there additional Hardware to make it work?
Thanks in advance
Hello everybody, I'm currently working on a project where I need to implement an IoT platform based on Microsoft Azure Cloud. Communication is...
113
Hi Everyone, We have Silo System which has temperature sensor and these sensor data will be communicating through RTU unit to the Dedicated PC...
645
Hello, Thanks in advance. How can I send more than 82 characters using AWA or AWT? to Zepra Printer via serial Rs232 communication? Normally I...
790
Hi all I have a project on the go and would like to send data from a Siemens 1500 to a Siemens 1200 What is the best function to use ,would it be...
4,529
Hi all, I've only worked on Profinet once before to talk between a few S7-300 PLCs. I managed to get the system communicating by using the "GET"...
2,616
