ASCII data sending issue via AWA or AWT at SLC5/05 CPU
sinanmoral
Apr 2020
Istanbul
52
Hello,
Thanks in advance.
How can I send more than 82 characters using AWA or AWT?
to Zepra Printer via serial Rs232 communication?
Normally I can send the data up to 82 characters but I need to send more than 82 characters.
I designed barcode using Zebra programming language and there are more than 82 characters (Text file) that i need to send to Zebra printer to print.
By the way,My ascii knowledge is limited...
My Cpu is slc5/05 and using serial Port 0 on CPU...
Thanks.
Can someone help me to find instruction which stores ASCII characters to String data type tag and Is it possible to convert an ASCII string to Hex...
4,615
Does anyone know how to inhibit the 232 module from sending data during PLC power-up? To send data during normal operation, the Transmit Record...
1,905
I am working on a project, inside an AB CLX, I implemented the Modbus TCP Client AOI published on AB website, to interreact with a Modbus ASCII...
3,572
Hey working on a project where I need to send a String Command to a device in order for the device to perform an operation. It's over Profinet but...
1,873
Hello all, as you probably are all aware I have been trying to interface an A&D GX4002A balance to a 1769-L24ER-QBFC1B controller by the use of a...
1,480
