1734-232ASC/C ASCII Module – Data Being Sent After PLC Power Cycle
LochRaven
Aug 2022
Auburn Hills, MI
Does anyone know how to inhibit the 232 module from sending data during PLC power-up? To send data during normal operation, the Transmit Record Number needs to change. The Transmit Record Number is not changing during power-up. When the PLC powers up, it appears that the data is being sent on first scan.
Thanks for your help!
Welcome to the PLCTalk forum community ! That is an excellent question.
My first instinct is to use the power-up handler and/or the S:FS bit to put a zero into the Transmit Record Number.
I would have to test to find out if zero is special on the 1734-232ASC. If you are in ordinary run mode and the Tx Record goes from 100 to 0, for example, does it transmit ?
Is this a 1769-L1x where the 232ASC will power cycle along with the controller, or is the 232ASC connected via a network adapter ? Does the network adapter power cycle along with the PLC ?
Thanks, Ken.
It's an expansion module on a 1769-L18ER-BB1B. So, the module will power cycle with the controller.
I'll try your suggestion tomorrow morning with resetting the transmit counter to zero.
Thank you for your time!
Hi All, I am new to this site and I am looking for some help, I am trying to send ASCII characters to a unit that performs a task via a...
43
17,028
Hey Guys, Thanks in advance for any help. We are converting our Compactlogix L32E application into the 1769-L18ER-B1BB. One major hurdle left...
6,406
Hello Friends I have took the sample program from AB webpage and modified, but I can only send 127 chars...
185
Having issues sending numeric display to Vorne 87-705-4D-4CTR scoreboard from 5069-L310ERMS2 with 1734-232ASC. I have Putty up on one of the...
2,556
Hi All, I'm trying to connect a 1734-232ASC to a ViewMarq overhead display and I cannot figure this out for some reason. I have the baud rate...
2,055
