Sending Temp Sensor data From Kepware 6.0 Software to MicroLogix 1400
prakasha
Dec 2022
Davangere, Karnataka, India
75
Hi Everyone,
We have Silo System which has temperature sensor and these sensor data will be communicating through RTU unit to the Dedicated PC system. This PC is also been installed with Kepware Application with licensed. All silo temp sensor data is communicating to the PC system through RTU and the challenge is we need to take this data to Allen Bradly Micro Logix -1400 PLC through Kepware application. we have a Kepware Tags ready from supplier.
can anyone put me through how can we Map the tags to read the data from Kepware to Micro Logix 1400 PLC. if you have any backup like photos and Logic or screen shot please share here. so that I can follow it.
Thanks in advance
If the Kepware application can send the data over modbus rtu, you can set the micrologix 1400 comm port as a rtu slave. Then create the data files and put them in the setup screen and that is where the data will be sent to.
I don't have kepware here at the moment but I believe you can use link tags, in other words, when one tage changes value it is copied to the other, I cannot show details until I van get to my other Pc with Kepware on it. I have not used it & only remember coming across something in the documentation.
I’m attempting to send a temperature from a SLC-5/02 to an EZiMarquee display. The vendor said to use a MSG instruction to send the data to the...
88
Hi I need to send a null command down a comms port. But in the crimson software when i used /x00 it coming back "Cannot use null character is...
421
I've been having some trouble figuring out how to get the ip address for the mail relay server, is it something that I need to create separately...
914
I've been trying to get this Ethernet module configured to send emails to our relay server but cannot get it to work. the EN2T is running...
1,762
I have a field device (flowmeter) using HART wired to a 200SP HART input card. I need to read flow totalization. Configuring the actual card to...
643
