CHANGE PLC S5 To S2-200
THELEM
Mar 2006
SANTIAGO
HELLO To ALL The FRIENDS OF THIS FORUM, I HAVE A QUESTION FOR YOU
I HAVE TO CHANGE SOME PLC S5 OF SIEMENS And I HAVE TO INSTALL THOSE OF The S7-200 SERIES,,,THE QUESTION IS....
I CAN UNLOAD The PROGRAMS OF EACH S5 And THEN TO DOWNLOAD THEM IN The S7-200 SERIES.
IS REQUIRED SOME SPECIAL CONVERSION, Or ARE ZERO COMPATIBILITY?
PLEASE ANY HELP IS WELCOME.
[email protected]
SALUDOS
THELEM
Thelem,
changing from S5 to S7-200 is a really, really bad idea. You'll have to rewrite every line of every program.
Now if you would change from S5 to S7-300, that's another story. Then you could make use of the S5-S7 conversion program, which can translate almost 90% of all programs completely, and about 90% of the rung in the programs it can't convert completely.
Don't forget: the S7-200 isn't a real Siemens PLC, it's a Texas Instruments PLC, which Siemens acquired by buying the TI PLC division. The S7-300 and S7-400 are the one and only real offspring of the S5 family.
Kind regards,
Thanks Buddy For The Advice!!!!!.
So, I Have To Give Me The Time To Remake All The New Programs From S5 To S7-200, Is That Ok?.
Bye
"chao A Todos Desde Chile"
Claudio
Hello,
Like Jean-Pierre stated try to avoid S7-200 PLC's try to use s7-300 ones, if you count your hours to rewrite the program into a S7-200 a convertion to an S7-300 program/PLC is mostlikely cheaper.
Hello, I am using CPU226 I have downloaded Logic with 9.6Kbps Baud rate.It running ok.To increase Transmission speed I have to use baud...
1,954
It might seem like a stupid question but please let me elaborate. I had a PLC that already had some IP address on it which I needed to change. My...
6,067
How to do that can any one give me the how to write instructions example
856
Hi! i'm just wondering did there is any chance to change Set Time(TV) on Siemens plc timer without step 7 using c# or python if timer not set in...
1,276
Morning All, So I have a PLC-5/30 with a 1785-ENET module that I am needing to change the IP address on. I know very little about PLC's but have...
1,924
