VBA FTView SE to Write to a PLC tag (Direct reference)
Jul 2007
Kiruna
600
Hi Guys,
I am having some difficulty getting some VBA to work.My VBA is bad...
I want to write a subroutine which takes 2 parameters 1. Value to write, 2. Tag Name and write the value to the respective tag.
Here is the sub:
Code:
Sub SetTagValue(valueToWrite As Integer, tagName As String)
On Error Resume Next
Dim oTag As Tag
'Make sure the tag group exists
If Not OGroup Is Nothing Then
Set oTag = OGroup.Item(tagName)
Err.Clear 'Clear out any old errors before the write
 oTag.value = valueToWrite
Select Case Err.Number
Case 0:
'Write completed successfully... log a message (If desired)
LogDiagnosticsMessage "Write to tag " & oTag.Name & _
" was successful."
Case tagErrorReadOnlyAccess:
MsgBox "Unable to write tag value. Client is read-only."
Case tagErrorWriteValue:
If oTag.LastErrorNumber = tagErrorInvalidSecurity Then
MsgBox "Unable to write tag value. The current user " & _
"does not have security rights."
Else
MsgBox "Error writing tag value. Error: " & _
oTag.LastErrorString
End If
Case tagErrorOperationFailed:
MsgBox "Failed to write to tag. Error: " & Err.Description
End Select
End If
End Sub
Now here is the call:
Code:
Private Sub Prefill_ComboBox_Change()
On Error GoTo ErrorHandler
If Prefill_ComboBox.value = "Not Selected" Then
    SetTagValue(0, "{::[Metso]Program:TUBE_1.Selections.Val_Prefill_Selection}")
ElseIf Prefill_ComboBox.value = "Prefill On Time" Then
     SetTagValue(1, "{::[Metso]Program:TUBE_1.Selections.Val_Prefill_Selection}")
ElseIf Prefill_ComboBox.value = "Prefill On Pressure" Then
    SetTagValue(2, "{::[Metso]Program:TUBE_1.Selections.Val_Prefill_Selection}")
    End If
But i get a compile error on:
SetTagValue(0, "{::[Metso]Program:TUBE_1.Selections.Val_Prefill_Selection}") saying
Compile Error := expected.
Has anyone any idea what is wrong?
Hi all. Currently I'm working on a VBa script for FTView. I would like to understand a bit better about some commands. 1) What are the...
598
Hi all. I'm running a VBA code on my FTView which is actually working, but everytime I open the display that calls the VBA code, it throws the...
28
1,806
Greetings, I have this question: How can I add a tag, in my case LS:0 {#5} (literal string of tag #5), to a variable using VBA? I couldn't find...
896
Hello Every one, I need a help on vba code for getting data from MSSQL server 2014 to display in FTview SE client version 12 . Thanks. Please...
1,815
I've been messing around with trying to find a way to clear all PlantPAx AOI latched alarms via the Alarm Banner or Summary objects. So far, I can...
1,737
