Vipa Profinet connection to Kolmorgen AKD drive problem
NoName
Sep 2003
Domžale
273
Hello all.
I have a strange situation on my hands.
I have a VIPA CPU 315-4PN12 with firmware v2.6.0. that I am trying to connect to a Kollmorgen AKD profinet servo drive, via profinet in TIA portal v15.1
When I downloaded the configuration to the PLC I get the following error in the diagnostics.
Module exists.
Error
Additional information for the module:
Differences were found between the loaded configuration and the offline project.
Online article number: AKD-Pxxxxx-xxPN-xxxx
Offline article number: AKD-Pxxxxx-xxPN-xxxx
If I apply the same HW configuration to an S7-1200 station I have this error message but the communication between the PLC and Serov drive works:
This difference is accepted by the system because the inserted module is compatible with the loaded module.
Any ideas on what could be wrong. I tried several different GSD's but it's always the same problem.
Cheers guys.
Aleix
Try the following link for the GSDML files required for Profinet:
https://www.kollmorgen.com/en-us/query/AKD%20GSDML/
I think you have to make sure you get the right version of GSDML for the version of AKD drive you have. The list in the link above lists different versions of AKD drive (ex: the latest one in the list is Release 1.18.00.004).
Hello. I have tried it, so that the firmware is identical to the GSD but the same error message is displayed in the diagnostics.
But at least the comunication has started to work...
Hello all. I have trouble getting online with TIA portal V15.1 with a VIPA CPU(VIPA 315-4PN12). If I try to connect I get an error message that I...
3,355
Hello all. I am working in TIA Portal V15 with the following CPU from VIPA: VIPA 015-CEFPR01 I configured the this CPU as a CPU 315-2 PN/DP + CP...
1,934
Dear sir, I am using SIMATIC 300, CPU 315-2DP , (6ES7 315-2AF03-0AB0) VIPA 603-1CC21 A1.0 RAM 32KB, Firmware=V4.0.8 The problem Im using MPI...
166
Got a VIPA 315-2AG23 that i try to go online with but can't seem to make it work through a network. I can go online if i'm plugged directly in the...
271
Hi guys, I have VIPA MCC 953-1LK00 1 MB, but it is blank. Does anybody have image for this card? Thx in advance.
809
