Difference of PLC with motion control and PLC without motion control
Usually motion control is that you have eg. cards in the PLC that can control stepmotors/FVC/drives directly. You only need to give the commands to the cards and they do the job. (control-feedback-errors and so on).
Hello !
It depends on what kind of PLC you have!
Usually the cards have an input for the encoder/s absolut or incremental then the card need some kind of outputs analog or/and digital, stepmotor outputs, fieldbus etc.
You must first know how makes the PLC and then you look at the manufacturer manuals.
Have you tried this?
nif said:
If so, how well did it work?
tanwillie said:
What is the difference of PLC with motion control and without it? Is there anyone can give a explanation?
Motion control cards off load the PLC and perform much better than soft motion control using software blocks or ladder. I can go on for pages on the differences. I would not consider a soft motion controller except for the simplest of applications with lots of PLC power to spare.
What happens to the control when the PLC stops scanning or get busy during a program update?
Hi; We installed an orifice plate type steam flow transmitter which configured to give 4-20mA signal correspond to 0-9ton. I given that signal...
24
5,611
I have a Automation Direct Click Plus that you can buy option CPU slot modules for input/outputs. The slot modules have the options of sinking...
2,832
Hi All, I am starting a project that contains RTU from SCADAPack 474. However, I have no experience with this equipment, I am familiar with...
3,212
Hello, Do you know what is the difference between the PID controllers PIDFF, PID1 and PIDP1 in a Schneider PLC? I have to modify a PLC program...
1,740
HI all, I have exported csv files from one of the application which was build in factory talk view. I'm seeing 1600 tags almost and doesn't...
2,331
