Difference between the PID controllers in a Schneider PLC
Frank_T
Jan 2020
Quebec
Hello,
Do you know what is the difference between the PID controllers PIDFF, PID1 and PIDP1 in a Schneider PLC?
I have to modify a PLC program with a new standard of coding. The new standard use a PIDFF function bloc.
If I change a PID1 bloc for a PIDFF bloc, can I use the same parameters Kp, Ti, Td?
If I change a PIDP1 for a PIDFF bloc, can I use the parameters Ki and Kd to calculating Ti (ti=1/Ki) and, Td (Td = Kd)?
Thanks you for your help.
Welcome to forum.
Is this homework or work?
You should look pid block structure, and if equation of blocks differs.
Pidff can configured either to paraller or mixed structure.
I am fan of expert system, and peter is trying to convince me of the opposite. BTW no hard feelings as both types have advantages/disadvantages...
19
6,561
Hi, whats the difference between the above two types of PID controllers. For example, there are the S7 PID blocks FB41 CONT_C and FB58 TCONT_CP...
8,427
Hello, I have a problem with AO- and AA-Tags. When I use for example the tag AO_Test with the address 200 and type the value 1,2 in, the AA-Tag...
1,415
As per the title. This might seem like a basic question to many, but I'm unclear about the difference between a coil ( ) and an application...
28
4,046
Good Morning , I have 2 Frequency Drive panels to build and commission . It is for 2 pump systems . Just wondering , what is the...
1,973
