Plc 5 q
On the left hand side of RSL 5 is your tree. If you scroll down just below your data files is a branch called force files, one for outputs and one for inputs. If you open these data tables then you scroll through them any bit with a 1 or 0 is forced.
RSL5000 has a search function which is faster, but I have not seen anything like that in PLC5.
And then once you see a forced item in the force files you can right click and choose Find All to locate it in the logic.
The PLC-5 and SLC 500 do not have a search for forces option like the 5000.
OG
48
the conveyor can stop because of a safety sensor or safety switch. And also it can stop because of an object jam detector sensor. If the conveyor...
123
Good Day to all of you, this is my first post, i will try to explain as best as possible, english is not my natural language. I am performing an...
29
206
I have a project to automate four generator sets. The system will monitor and store the load demand of the factory. Once there's Power outage, the...
57
