Plc 5 q
On the left hand side of RSL 5 is your tree. If you scroll down just below your data files is a branch called force files, one for outputs and one for inputs. If you open these data tables then you scroll through them any bit with a 1 or 0 is forced.
RSL5000 has a search function which is faster, but I have not seen anything like that in PLC5.
And then once you see a forced item in the force files you can right click and choose Find All to locate it in the logic.
The PLC-5 and SLC 500 do not have a search for forces option like the 5000.
OG
30
Hi, I'm trying to import a Rockwell/AB EDS to Beckhoff but I'm not sure how to import/install the EDS. It is a PowerFlex 525 EDS. Is there a way...
64
I want to communicate my Q series PLC with Factory IO using GX works 2 software, I want to use modbus as server and the ips are as follows plc...
44
Hi everyone. I'm trying to read values from a Loadcell with a 2080-TC card. I know the 2080-TC is a thermocouple card but it reads millivolts that...
84
Hello All, Please direct me to post to the right page. I am really new to PLC, and want to find a tutor who is familiar with Automation Direct's...
212
