FIFO instruction in Melsoft Gx Developer to RsLogix 500
epicnote
Feb 2011
Malaysia
45
Hi all,
How to apply FIFO instruction in RsLogix 500 so that it can operate same like FIFW/FIFR from Melsoft?
Thanks in advance
Epic,
That is a tough question. To answer well, a person would have to be very familar with both RSLogix500 and Melsoft. I am familar with RSLogix, but not Melsoft. Perhaps if you could post the details of the the FIFW and FIFR instructions, I could help you to find your answers.
It is Melsec A series PLC. Attached is the detail for the FIFW/FIFR instruction. Hope you guys can help me to apply this instructions in RsLogix 500.
Epic,
It looks like you are going to have an easy task to make the conversion. THe FIFW appears to be very compatible to the RSLogix FFL (FIFO Load), and the FIFR is similar to the RSLogix FFU (FIFO Unload).
Melsoft FIFW parameter (S) = RSLogix FFL "Source", stores the value to be entered next into the FIFO stack.
Melsoft FIFW parameter (D) = RSLogix FFL "FIFO", is the address of the stack. The same address is programmed for the FFL and FFU instructions.
Melsoft FIFW parameter "Data storage position" = head address of data table + content of pointer, where RSLogix FFL and FFU "Position" word is the next available location where the instruction loads data into the stack. This value changes after each Load or Unload operation.
The RSLogix FFL and FFU also have additional parameters, such as Length (total number of stack words), and the Control file address, where the status bits, stack length, and the position value are stored.
Hey guys, I have a scenario where I need to fill a data register with characters, likely alpha numeric. Lets say I have 4 momentary push...
1,968
I am working on a new project in an injectionmolding facility to control the material distribution system. I am looking for an instruction\...
1,134
RSLogix 5000 Compact Logix controller Could someone give me an explanation or post a link to an explanation for the use of FFL and FFU...
3,548
hi every one, I have a question about FIFO instruction, i need to to store data in just like the fifo does, but i need to do it with float point...
3,098
Hi i'm trying to use PUSH and FIFO but it seems not to work just like i need or probably i'm doing something wrong, here is the problem: I do...
6,798
