Global Data Communication with Siemens S7-300
M/B
Apr 2006
Lokeren
I'm having some trouble generating a communication error on a global data communication link using a Siemens S7-300 setup.
The guys & girls who have already worked with this setup will know that you can pick up on a communication error using the GDS, the Global Data Status. This is a Status Double Word from which you can monitor bits that tell you when a communication fault occurs. In order to simulate a communication problem, I've pulled the plug of the MPI network cable while monitoring the GDS, but I don't see any bits changing.
If anyone of you has experienced similar problems or succeeded in configuring Global Data Communication with the same setup, please feel free to share the knowledge.
Thanks.
In GDS communication table,two nos. configuration is require.
1.Send Bit/Byte/WOrd/DWord -CPU 1
2.Received Bit/Byte/WOrd/DWord- CPU 2
If communication problem is create the Bit/Byte/WOrd/DWord will be
changes in CPU 2 as per your program configuration.
Thanks!
Hi, I was trying to restore a .cab file and it was stuck at 70% - restore global data for nearly 2 hours. What should I do from here? I just...
1,507
Hi I am passing data between 2 x 90-30 PLCs over ethernet using Global Data. This works well using Produced and Consumed data. Is there a way to...
1,550
Hey guys, I"m at the point in my project with RX3i controllers that I need to get comms working between two PLCs via EGD, and it's been an...
4,419
Just a quick question I can't find an answer on yet. I have created my own recipe structure using a Global DB and when I came in this morning...
2,017
Good day all! I am to communicate two S7 300 CPUs via MPI and I wish to accomplish this using MPI global data. So what I did was setup the GD...
1,921
