GE Fanuc 90-30 Global Data Status Check
Bilbo1161
Sep 2015
UK
51
Hi
I am passing data between 2 x 90-30 PLCs over ethernet using Global Data.
This works well using Produced and Consumed data.
Is there a way to know that this data is being transmitted and recieved at either end?
Does this data get sent on a clock pulse or it it just send on data change.
Thanks for any help on this mattet.
The data gets refreshed at the rate specified in the configuration of the exchange in the Proficy project file.
Thanks Steve
Do you have any knowledge regarding knowing that i still have a live ethernet connection between the 2 PLCs, or do I need to run a rolling integer to read from one PLC to the other?
I need to verify what I'm going to do is somewhere near correct. Using VersaPro 1.5, CPU352, BEM331 I need to write 24 %R's to S6 Registers and...
5,862
I have a CNC cutting equipment, all the components are Fanuc from the CNC CPU A02B-0307-B822, a PLC AIF01A and a panel i, on the panel i (operator...
115
I want to buy this program if anyone has it. Absolutely no one has it officially for sale. My cpu is IC610CPU104B My mail...
114
I've got a Micrologix 1100 with ethernet and I'm trying to configure communications to a Fanuc R30iB controller. I'm pretty sure you have to set...
107
We recently purchased a IC693CPU352 module and it appears the internal time clock is static. I can set the time and date but once set it does not...
174
