GE Fanuc 351 convert LM90 to PME
tarik1978
Mar 2010
casablanca
717
Hi, could someone do a favor for me:
I have a program in logicmaster 90 writen in SFC
When I try to import program in PME I got an error, logic isn't imported
Is there an add_on to PME to recognise the LM90 SFC
If not can someone provide the printout of the progam?
one more question if I burn the program in EEPROM and place it in the PLC,can I restore the program to RAM
o_Oo_Oo_Oo_Oo_Oo_Oo_Oo_O
lm90
good morning, could you help me print a program that is created on lm90 because I don't have the sfc function enabled on my lm90, or could you explain to me how to enable that function so that I can edit the program.
I would appreciate it. My email is [email protected].
who can help me with this problem
I believe you can print the SFC listing even though you don't have the capability enabled in your Logicmaster installation.
To be able to edit you will need the 3-1/2" floppy disk with the SFC installation. If I remember correctly, it can only be installed from the floppy, meaning you can't copy from the floppy to the hard drive or to a USB thumb drive.
I'm working on a 90-30 PLC which keep losing its program everytime it is powered down. We first figured it must be a battery issue, so we tried...
1,319
[/IMG] Can I use a usb to serial converter to connect to the cpu port 1 (RJ11)? And also which software do I need? Thanks
2,520
The PLC has a program in it that possibly programmed using LOGIC master, which I do not have. Prior purchasing "Proficy ME 8.5" I talked to GE...
3,040
I am setting up a bench practice unit consisting of a 5 slot rack (IC693CHS397C), POWER SUPPLY IC693PWR330C, cpu 351,and one input and one output...
3,879
Hello, i am using profibus as communication between plc and fanuc arm. I can easily send inputs from plc to arm, but i can't monitor any outputs...
54
