GE Fanuc 90-30 cpu 351
nmk
Dec 2002
38
The PLC has a program in it that possibly programmed using LOGIC master, which I do not have. Prior purchasing "Proficy ME 8.5" I talked to GE tech support and the vendor, and they said I should be able download and upload the plc program easily. I can connect the CPU and upload the program into new project, but when I validate the uploaded project verses what in the processor, I get not equal. after the program upload, the software indicate that some areas in the program will not be transfer like %T. Prior the GE free technical support ended after purchasing the software, I remember one tech. told me to download what I uploaded to make them equal, I was afraid the consequence CPU does not run the same due to incompatible instruction set or other functions between logic master and Proficy ME. I am putting as much information as I think might be relevant to my question. what to do to making them equal?
Your memory of what the technician told you is correct. You will not be able to get to a "Logic Equal" state until you download from Proficy Machine Edition to the PLC.
The key point is to make sure that the result of the validation is good. It's OK to get warnings, but if validation results in any errors you will need to correct the errors before you can send the program to the PLC.
I'm working on a 90-30 PLC which keep losing its program everytime it is powered down. We first figured it must be a battery issue, so we tried...
1,309
I am setting up a bench practice unit consisting of a 5 slot rack (IC693CHS397C), POWER SUPPLY IC693PWR330C, cpu 351,and one input and one output...
3,863
We recently purchased a IC693CPU352 module and it appears the internal time clock is static. I can set the time and date but once set it does not...
170
Dear Everyone I work with PLC GE-Fanuc. But I don't know that "PLC GE-Fanuc (Series 90-30 and VersaMax) can Online Edit Programming while...
3,049
Hi guys. Im a total PLC noob. i suspect a dead 331 cpu. Unable to communicate with it using the LM90 start utility. But i could on another CPU...
2,931
