ge fanuc lm90 cpu 351 Program
VJTX
Oct 2007
TEXAS
126
I am setting up a bench practice unit consisting of a 5 slot rack (IC693CHS397C), POWER SUPPLY IC693PWR330C, cpu 351,and one input and one output module. The old cpu was out of a machine from about 1994. All is good except that when the power is cycled, the config and logic reverts back to the original program. The program must be reloading from an eeprom, but I cannot write the eeprom, tells me (from LM90) that I do not have sufficient permission, or something to that effect. I suspect this is why the old program appears after the reboot. Any ideas? My new program does run, until power is cycled.
Thanks, that is set correct, but made me remember the keyswitch. I put it in the horizontal position, then I was able to write my program to eeprom. Problem solved.
Hi, I am new to GE Fanuc LM90-30 and this morning I was asked to upload PLC program from an online-running GE Fanuc LM90-30 series with the CPU...
2,456
can anyone can gave a link or can upload software of ge fanuc lm90 software? this will help me a lot to troubleshoot my ongoing task..thanks
3,006
Hi, could someone do a favor for me: I have a program in logicmaster 90 writen in SFC When I try to import program in PME I got an error, logic...
3,143
We have an old machine with a GE Fanuc 90-30. We need to reload the program, I have an original on floppy that was made using LM90-30 V4. Our old...
2,995
body Attached are a few pictures of AVS Reclaim Furnace and control cabinet The I/O configuration Slot # 2 Analog Input 4 ch IC693ALG220f...
2,127
