Help converting GE Fanuc LM90-30 v4 to ME
dpjkw
Mar 2008
USA
We have an old machine with a GE Fanuc 90-30. We need to reload the program, I have an original on floppy that was made using LM90-30 V4. Our old PC that had all our DOS software on it died several years ago, and I can't find the floppies (I do still have the SN) and all I now have is Machine Edition. According to GE the pre V6 has to first be converted to a post V6 then it can be imported into ME. Can anyone assist? Thanks, Jim
:confused:
:confused:
Zip the version 4 files and post here, someone will bring them up to date for you. If no one beats me I can do it tomorrow around noon, if all goes well.
Here is the Project convert. I converted it using ME 5.6 so you should be able to open it. Just open ME File Restore Project and locate the zip.
Hello nice to meet you, im new in here, I'm currently trying to convert code written in STL for a S7-400 to SCL for an S7-1500, because when i run...
320
Hi! I am working on a project were we will be replacing an 300 CPU with a 1500 CPU and we are working on migrating / converting code. There is a...
1,079
Hi! I need help converting an old MicroLogix 1100 project to Micro 820. Project Details I have an old MicroLogix 1100 program that has been in...
475
Hope someone is really bored this late on Memorial day!!! I have spent the last 5 hours researching this and trying everything I could find on...
3,280
I am needing to convert the low DWORD of a timestamp into a LREAL. The DWORD is a 32bit unsigned number. In TwinCat2, I keep getting a negative...
1,688
