Wht's a Virtual Machine
besc
Mar 2014
California
36
Like I've stated, been out ot this for a long time so be patient. A couple of people responded to my last thread saying they use a virtual machine for there programming enviornment when programming in Allen Bradley. I plead ignorance. Are they simulators, emulators etc. I need educated on this. Sorry. Mike.
besc,
a virtual machine (VM) is basically a pc running inside another pc.
for example, my host machine is a dell with windows 7 sp1 64 bit with 8Gb of ram.
at the same time i run several windows xp sp3 vm's - ab plc programming, autocad, and wonderware.
regards,
james
A Virtual Machine is an Operating System running on virtual hardware. Basically it allows you to run more than one operating system on 1 set of hardware at the same time. There are A LOT of different methods to achieve this that get VERY details and technical, but that is the basics and all you need to know for what you are trying to do.
hello all i want toknw wht is exactly a osr bit how it works thanking you
2,247
Hi all, I would like to replicate my PC onto a virtual machine so I could use it on a different laptop when I'm on site. I have never created a...
287
...and I agree. Context: TIA Portal/HMI = KTP1200 (12" screen) In the attached redacted image, the values in the white boxes are entered by the...
798
Is there any way to use a Virtual HMI (running on a PC) with CCW? This is for an application where there will be an actual HMI (PV800) connected...
433
i have a dell laptop with a real com port host OS is windows 10. Running VB 6.1.42 I cannot get the serial port to configure in VB. Please Help...
1,064
