DAServer doesn't connect to SMC
Jerry321
Dec 2017
Kuala Lumpur
FSGateway was not appear in the SMC. The log file showing:
Warning DAServerManager GetInstalledServers method failed, hr=80070005
How can I fix it? Please Help.
0x80070005 is access denied. This could be a DCOM setting but if this was working and now is now is not and you are running on a Windows 7 or higher operating system it is possible that you recently installed a patch from Microsoft that Mitigates the threat of the Meltdown and Spectre vulnerabilities.
We know that the following updates to Win 7, 10, and 2016 have had impact on OPC Classic connections, specifically COM and DCOM.
https://support.microsoft.com/en-us/help/4056894
https://support.microsoft.com/en-us/help/4056892/windows-10-update-kb4056892
https://support.microsoft.com/en-us/help/4056890
The OPC Foundation has initiated a call/case with Microsoft, who by the way is a member of the foundation as well, to look into the impact and ways to mitigate the vulnerabilities without impacting COM and DCOM so dramatically. The the link on the foundation forum about that.
https://opcfoundation.org/forum/cla...l-da-etc/problems-after-windows-update/#p1001
For those that have been in the industry long enough you may recall a similar problem when Microsoft released XP SP2 which not only broke OPC but also broke most of the Microsoft apps as well. So it will get fixed but it will take a little time and everyone will need to be patient.
Now you can back out the security updates but that means that if your PC's can be reached outside of your plant either directly or indirectly they will be vulnerable to these exploits.
Thank you very much!
I am using Win10 version 1709 (OS build 16299.192). I also found that the OPC server can't connect since windows update, but I thought was because my setting or software issue.
Btw do you know where can I get the latest update about this issue?
And again thanks for help @Fred_Loveless
I'm getting errors in SMC as follows: 737700 12/11/2021 10:21:54 PM 2620 5640 DASProtFail DASMBTCP Unsupported function code 1 (Hex), in...
1,691
Having a Issue at a site where WOnderware can seemingly connect to the PLC and all shows good except its locked into a loop for downloading the...
1,801
I am trying to break the link between a wonderware tag and a tag in RSLogix. No matter what i do to the tag in the PLC the wonderware is holding...
1,766
Hi, I have a Legacy project that I have converted from Intouch 7.1 to intouch 11.1 now running on windows 10. I have also uprevved the DA Server...
3,550
Hi all wonderware users As I'm new to this and cant find a solution for the error message STS=1E I'm using a Intouch v10.5 connectet to...
3,511
