WinCC Flexible, grafical tips ? or navigation tips ?
userxyz
May 2002
any
2,768
Hey,
I'm making some screens with 8 double measurements / screen. 2 bars that can mount up to 200 degrees Celcius. Are their any particular examples of how it's best done, this is one of my first projects where I use bargraphs. Is it also good to place a button with the function key mentioned ?
So, what have I done, wel, I've made a faceplate for the first time in my life:
Maybe some tips to be better ?
Looks good I think.
Are these PID loops, and the red and blue bars are actual and setpoints respectively ?
If they are PIDs, then you could add a button that grants access to setup/tuning parameters. I would also add an explanation on what the blue and red colors means.
hey
JesperMP said:
Looks good I think.
Red = temperature of the carpet
blue = ambiënt temperature
Just visualisation, nothing more, the trending of these measurements happens on an ifix system. So this is only for local visualisation, nothing more
And indeed, telling what the red and the blue bar is, is a good idea
thanks
This is my attempt at a PID setup and trending screen - getting into faceplates now I have a bit of time - got bored with the concept before , but really see the value of it now
I am trying to develop a fixed standard for all screens.
Anybody tried to use a faceplate including a trend view ?
I have , and have declared a structure that mimics my PID interface structure , but don't seem to be able to point the trend objects at the structure .
more tips ? Graphical tips...
Some more screens, maybe extra tips ?
As I'm learning and improving myself... tips are welcome
Well Siemens have also confirmed that it isn't easily possible to add a trend to a faceplate without using static data , which kind of negates any benefit for doing so - I am going to have a go at writing a script based upon screen name and copy static variables to internal tags so that they appear to be dynamic - but not the result I was looking for .
Hi, We have upgraded our laptop which includes Windows 11. It appears that WinCC flexible 2008 advanced does not support Windows 11. What...
265
Hello everyone I Have an Issue with the usage of recipes in Wincc Flexible 2008, I create the recipe to change the values in a fast way The...
106
Hi colleagues.We do data logging system.We want to record three temperatures under a certain condition. We prepared the project as follows. We do...
755
Hello to everyone. I change the value of a "PQW" with a button in Wincc flexible. The code of the button is defined as M102.0. Value reset...
4,576
Hello Friends I have installed WinCC Flexible 2008 SP5 Update 2. I have open the software, but the Transfer option does not appear. Is It...
1,476
