S7-200 Status Chart error
ceystath
Jan 2009
Larissa
Hi everyone.
I have a problem that appeared to my S7-200 from Siemens today and I am not sure what is happening. I had some operations performed with some math and move blocks in ladder. Everything worked perfectly till midday today. At some point I tried to debug by Program Status and by Chart Status. While the values display correctly in Program Status and the PLC seems to work correctly to inputs I provide, the Chart Status has gone crazy. On a standard move command (MOVE REAL), with a 400 as entering value in status chart appears as output +1137180672. The rest of the values in the program behave the same way, except one in the middle of the operations that is displayed correctly. I tried different computers and I also tried an older version of the program that displayed correctly the values. The effect was the same. Is my S7-200 fried? Will I be pushing my luck to use it anyway since the Program Status and real/live functions work correctly? And moreover, is there a way to fix this problem? Has anyone seen anything like that before?
Thank you very much for your attention,
With Kind regards,
Efstathiou Chrysovalantis
+1137180672 is the decimal representation of the floating point number 400.0
I've not used the S7-200 so I'm not familiar with how you change the representation of numbers.
Dear Kinetix experts, Would any of you be kind to check and help me to resolve the following problem with Kinetix 6200 Safety module...
1,018
I have a siemens 1500 which is connected to several chargers and are connected via the modbus MB_Ciient protocol. Under normal operation, devices...
1,117
Hello everyone, I have 8xS71200 cpu fitted profinet with Wincc RT on pc station .I use tia portla v13 sp1 and i want to check and show current...
9,600
Does anyone know if the Siemens S7-1200 family of processors has a register I can watch to see if the processor is in run mode? We have a counter...
8,597
Hi,Can I monitor status of subrutine in s7-200 individually?(In s7-300 i am using Call enviroment,but with s7-200???) I used one subrutine many...
1,077
