RSLinx To Excel Link
Jim Davie
Mar 2003
Near Glasgow, Scotland
I want to populate an Excel spreadsheet using RSLinx. It works fine with Excel on the same machine as RSLinx but not if I want to share the file and access it from another network location. If I try this Excel looks for a local install of RSLinx to run. Is there any way round this.
Thanks In Anticipation
Jim
We save the spreadsheet every minute with a macro as a web page on our common network hard drive, and everyone at the mill can check it with a "favorites" link
I've done a simlar thing using an InTouch I/O server and nett dde how are you trying to get the data fron Linx to excel.
Jezz
A DDE topic is set up in RSLinx pointing to the PLC in question and the Excel cell references this topic and the integer address of the data we're intersted in.
Vetteboy, do you have a copy of the macro you could let me see ?
Jim
Have you got the nett dde format right?
i.e
\\<pc name\<application name>|<topic>!<item>
e.g
\\PC123\RSLinx|ABPLC!'B3/0'
Also is the host comp set up to share this program on the network..
Hope this helps
Jezz
Sub Auto_open()
' Auto_open Macro
Application.DisplayAlerts = False
ActiveWorkbook.SaveAs Filename:= _
"P:\Maintenance\electrical\PLC DDE\MillOperations.htm", FileFormat:=xlHtml, _
ReadOnlyRecommended:=False, CreateBackup:=False
Application.OnTime (Time + TimeValue("00:01:00")), "Auto_open"
Application.DisplayAlerts = True
End Sub
Vetteboy please a little help
Vetteboy
I got a real nice excel sheet with all my data from several processors. I tried your macro and keep getting errors. I cut out your direct to your Htm and inserted mine....the marco runs ok but will croak on the first write. I entered this macro in the excel file that has the DDE links established and running. Can you paint a picture for us PLC / excel savvy and Visual Basic handicaped?
Sub Auto_open()
' Auto_open Macro
>>"P:\Maintenance\electrical\PLC DDE\MillOperations.htm", >>FileFormat:=xlHtml, _
End Sub
Thanks Vetteboy
Steve
Basically I just recorded the macro by having it copy my clicks and keystrokes. I named it Auto_open so it would run as soon as the spreadsheet is opened. I added the line for turning the display alerts off and on, and the line about saving it every minute. I actually have about a dozen macros all doing various manipulations to our data and I threw this one together to show how the saving as a web page every minute works. I am using Excel 2000, could your version be different enough to not work properly?
Hi All, I have been doing MS Excel worksheets collecting data from ML1400 via RSLinx OPC / DDE Topic. I have made it work but when I am doing new...
3,423
I have previously collected data from RSLinx through Excel using "soft links." This worked perfectly for what I needed. At the time I also tried...
2,117
I am completing a project that ties an excel spreadsheet to a micrologix through RSLinx. I want to limit the traffic and take advantage of block...
4,877
Hi, I'm brand new to the forum and spent some time looking around but could not find an answer to my question. I'm using an excel spreadsheet to...
1,339
Hello! I am trying to help a coworker get access to a company dashboard. It runs on my computer and I have set up similar dashboards myself, so...
2,519
