RSLinx setup for DH+ through Ethernet
Dariusincj
Jul 2011
Missouri
43
I have a micrologix 1400 Ethernet connection out to an Ethernet hub (connects PLC and HMI to programming port on the cabinet). From the hub it has an Ethernet connection to an AN-X2-AB-DHRIO from Prosoft which is connected to the rest of my SLC-504'S via DH+. I've got the connection to get online with the SLC's by connecting to the Ethernet port and using the Gateway setup to connect to the DH+. Does anyone know how I would set up RSLinx to connect to the Micrologix from one of my DH+ connections?
Looking through the literature, that's not an example application they describe as possible. You could quickly find out by creating your DH+ driver in RSLinx, and see if the station# of the gateway appears. This is all assuming you pc with RSLinx is connected to the DH+ side.
Hiii
I have configured AN-X2 in past
Step 1 . You have register the EDS file for the AN-X2 gateway.
Step2. You have to set the IP address of AN-X2 gateway in computer IP range.
(There is a default set Ip gateway . Follow user manual first you have to change it to your computer range)
Step 3 . In Rslinx under Ethernet Ip driver U can see AN-X2 gatway.
Step4. Brwse AN-X2 and in DH+ nodes . your SLC will be online.
The way our plant is layed out, I'm limited on how I can connect to different machines. Right now I am pulling data from RSLinx OEM to an Excel...
2,123
Does anyone know if there is a way to import RSLinx Classic data into FT Linx? We have a quite extensive configuration set up, and it would be...
2,712
Hello, I am remote with a client, and the **** was setup, i can ping it, how I can work with the maple systems hmi without problems. However...
1,481
Hello everyone, I have to connect to an old PLC firmware (V13 of Flexlogix). This requires a Hyper-V (Microsoft owned) Windows XP Virtual Machine...
3,338
Hello Friends, 1. How can I connect to PLC5/30 via Ethernet (Rslinx)?. I have not worked on PLC5 before. is it same procedure as MicroLogix...
2,227
