RS485 15 pins to RS485 9 pins !!
manmeetvirdi
Oct 2004
India.
750
Hi there
I need to comunicate CP340 (RS485 15 pins) to Message didplay board (RS485 9 pins). Problem is I need a cable diagram of RS485 15 pins to RS485 9 pins.
Regards
Ok do you mean that get the pin details of both the device and then match it like for example:
Pin 15 Tx (15 pin side) should be connected to pin 4 Rx (9 pin side)??
OK then for sure all the 15 pins are not being used at 15 pin side.
I think minimum of three pins are required for communication, and maximum of 9 pins !!
Ok my work starts now.
Unless "Message Display Board" is a well defined Siemens thing I think we would have to see the port characteristics of that board before making any statements on how to connect them. For us to help we would need specific identification for "Message Display Board".
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
221
Hi, Seeking consultation on an implementation matter, and have a question about Modicon Compact 984 communication through RS485: Three Modicon...
215
i have an device which can support serial (RS485,RS232),CAN protocol . i want to connect it to an existing MIB 1553B bus ,what device will I need...
97
Hi all, I am trying to do Modbus communications via the CB1241 RS485 Communication Board on a Siemens S71200 PLC. I am using a 1215C CPU. After...
254
I'm trying to use a Red Lion Cub counter (Cub5B00) as a counter and give the cub's counts to a Graphite G12 PLC/HMI to display. After about an...
111
