1769-HSC/B module for Turbine Meter Application
ChownutZ
Oct 2011
Canada
Hi All,
Sorry if this has already been asked but I could not find more details for this type of application.
I have not used a 1769-HSC/B module in compact logics before. We normally use the Spectrum Counter 1756-CTR8 modules in the control logics.
In that type of application, we just took the rate for channel x and divided it by a k factor to get a flow rate in the units we needed.
And the same type of math for the volume using the raw counts.
I was just wondering, since i can't test this live since we do not actually have these cards in the office, if i would be doing roughly the same with these modules. I see they have built in data types when i added the module to the project and I do see a current rate, current count and stored count.
I am hoping someone here has used these modules in similar application and let me know if I'm on the right track? I spoke w/Rockwell support and they could not find any sample logic using turbine meters to send.
Thanks.
I have a problem with a AB 1769 hsc/b module. I want to save a pulse value and I put it into the preset register which will get transferred to the...
3,231
I have a MICROLOGIX 1500 system which includes a HSC module. One of the counters is configured as a ring counter. When the counter overflow bit is...
2,899
I am using a Micrologix 1500 with a 1769-HSC module. It is configured as a ring counter. The counter changes upto the max value and overflows to...
1,503
Greetings everyone, I'm looking at the wiring diagram for the 1769-HSC module, and I don't see how one would wire 4 discrete inputs to it. I can...
6,040
Hi All Using compactlogix & rslogix 5000 ver 15 If I get the pulse input in inputstateB1. Do i get the rate and count in Ctr0CurrentCount &...
4,313
