Help on 1769 HSC module
briana banks
Jul 2005
242
Hi All
Using compactlogix & rslogix 5000 ver 15
If I get the pulse input in inputstateB1.
Do i get the rate and count in Ctr0CurrentCount & Ctr0CurrentRate ?
Which parameters i need to set?
Thanx
First Briana you need to stick with one thread and work out your problems with the 1769-HSC, that way the rest of the users including me can keep up with where you are at in your problems.
Below are additional threads that pertain to this matter
http://www.plctalk.net/qanda/showthread.php?t=27944
http://www.plctalk.net/qanda/showthread.php?t=27836
Do you need the frequency(rate) and count? You can only get one. If you need the count then you will need to calculate the rate. This isn't a problem, just need to know up front
THIS thread goes into the rate and frequency a bit. It is for the 1756-HSC but the principle is the same.
I'm short on time but will try to get into specifics later. Let us know if you need the rate, frequency, or both
TW
Hi & thank for your comment.
I only need the rate i.e. pulse per second
the rest i can calculate myself.
are you sure i cant get the count and rate ?
Hello all. I am having trouble setting up my HSC to count pulses from a prox switch. I have it wired to the prox and I see the .InputStateA0...
1,374
So I have to encoders with A,B and Z pulse 360 encoder wired up to A0+, B0+ and Z0+ and the - pulses wired to common 24vdc. I can see the inputs...
1,042
Hello All, This is my first time working with encoders and I am a little lost. I have a 1769-HSC/B card on a Compactlogix L32E controller running...
3,003
Hi, guys, how going? Could you give me a hand on my small project? One part of the project is that we want to use a shaft encoder (part number...
1,304
I am new to RS logix 5000 and looking for help on configuring the HSC and how to unable movement in a motor. Does anyone have any advice or a...
2,989
