Micrologic 1500 with 1769-HSC card in slot 2 help
Dariusincj
Jul 2011
Missouri
43
So I have to encoders with A,B and Z pulse 360 encoder wired up to A0+, B0+ and Z0+ and the - pulses wired to common 24vdc. I can see the inputs come on, on the card. But I'm unsure on how to set up the configuration on the card in Logix. I can see I:1.0 count up to about 28 but I'm new to the HSC cards. I need a raw value that I can scale and use.
Help I Need Info To Program Plc To Control Dc Drives.i Have Compact 1769-of2 For Analog Output (0-10vdc).i Will Use Existing Mom. Push Buttons For...
1,898
Can anyone here refresh my mind on how to perform addition on 33 floating point variables? F8:1 to F8:32. the result should be in F8:0
2,002
Hi I have a micrologix 1500 controller that has a sticky relay output. The controller is comprised of a processor and base unit. I just wonder if...
1,842
Hello, Im trying to set up this pannel with a 1500 ab micro, a flow pc, tuch screen and a radio. I have everything runing up to speed, but when i...
2,322
need help on MicroLogic 1500 online monitoring, what is the best way to connect a PC to micro logic 1500 PLC. what kind of cable is needed?
2,764
