Micrologic 1500 query
sparko
Mar 2007
CHESHIRE
27
Hi
I have a micrologix 1500 controller that has a sticky relay output. The controller is comprised of a processor and base unit. I just wonder if someone can confirm that it is the base unit I need to replace(I'm 99% sure I just want to be certain before I give my boss the order)
Mike
Supression 101
If you are using relay contact outputs to switch DC inductive loads, make sure you have snubber diodes at the load, or you will be on a repetitive replacement schedule of the contact output base units.
So I have to encoders with A,B and Z pulse 360 encoder wired up to A0+, B0+ and Z0+ and the - pulses wired to common 24vdc. I can see the inputs...
1,042
Can anyone here refresh my mind on how to perform addition on 33 floating point variables? F8:1 to F8:32. the result should be in F8:0
2,010
Hello, Im trying to set up this pannel with a 1500 ab micro, a flow pc, tuch screen and a radio. I have everything runing up to speed, but when i...
2,323
need help on MicroLogic 1500 online monitoring, what is the best way to connect a PC to micro logic 1500 PLC. what kind of cable is needed?
2,766
Help I Need Info To Program Plc To Control Dc Drives.i Have Compact 1769-of2 For Analog Output (0-10vdc).i Will Use Existing Mom. Push Buttons For...
1,898
