RS logix 5000 1769 HSC help
bhorn847
Apr 2014
dafter
I am new to RS logix 5000 and looking for help on configuring the HSC and how to unable movement in a motor. Does anyone have any advice or a chunk of code i could look at to help? I have some background is RS Logix 500..
1769 HSC RS logix 5000 help
To clarify my problem a little bit, is rs logix 500 i had a soft reset bit for HSC as M0:5.1/4 and M0:6.1/4. I also had to enable movement as MO:5.4/1. I cant for the life of me figure out hows these translate to RS Logix 5000, or how to reference ranges of movement. Can any one shine some light on this?
Has anyone experienced the following issue on RSLogix5000 (currently on V16) I have a PLC program that has been running on a site for a number...
1,614
Hi everybody: Is it possible to program the compactlogix 1769-L32E LOGIX 5332E v20 processor with this software? thanks
5,294
I have installed 1769 IF4 analog input module in compact logix rack slot 3. I have an existing 1769 8 channel input card in slot 2 already...
2,457
Good Morning , I have a MicroLogix 1500 program I would like to convert to a CompactLogix 1769-L18ER. Can I use the RS Logix 5000 Tools/...
4,028
Heres what im using 1769-L24ER-QB1B AB Compactlogix controller 1769-IF4 AB 4 IN Analog CompactLogix 1769-HSC AB High Speed Counter Module 1769-HSC...
5,431
