i cannot read from the DELTA DVP28SV PLC registers?
nura91
Jul 2012
dama
hello everyone,
I'm using labview (very close to CITECT) to communicate with a DELTA DVP28SV PLC. I managed writing to a coil to to turn a fan on, and I also wrote to a register.
However, when i tried to read the coil (same coil i just turned on) or when i tried to read a register that im very sure has values (the register where i configure the modbus parameters), it would return ZERO, even when i tried to read the register that i just wrote into the reply was zero (I am sure that writing to the register was successful because i made the specific value that i wrote to the register a condition to turning a light on).
So, anyone knows why this could happen?? the Registers are Read/Write. I thought it could be that the scan time in the PLC is too short so i added delays but anything i read still gives zero back. ideas? can anyone help me with this?
here's the PLCs application manual in case it matters : http://www.delta.com.tw/product/em/control/plc/download/manual/DVP-PLC-Program_O_EN_20120416.pdf
btw regarding the coil, i gues it just turns on for a little amount of time that turns on the fan on some rising/falling ednge. but what i need to know is why i cant read the data register? I'd appreciate any help, especially a quick one~
Good day. The problem is the following, I am using the Machine shop parker program to program an HMI that communicates with a logix5573 PLC. I can...
1,276
1,419
Hi everybody Does anybody have experience with the Analog input card 1746-N18? Cannot get the last 4 inputs (4-7) to work like the first 4 (0-3)...
2,989
Hello everyone, I am currently working on a project that uses a Rockwell L33ER controller and the FTV Studio V13 as Supervisory computer...
151
Hello Friends I have a backup that I am trying t open in mi PC (RSLogix 17.01) and I get this message. I have read many posts and done many...
200
