Standard USB lead for Schneider PLC?
JasonWade
Oct 2005
Preston
160
Does anyone know if I can use a standard USB Mini B lead for download to a Schneider M258 PLC and a HMI STU 655. Or do I really need to spend around £70+VAT on the two leads Schneider list (BMX XCA USB H045 and BMX XCA USB H018).
Ok thanks MrQ. Can you tell me anything about uploading the project from the PLC/HMI.
The situation is this; A customer is asking if I can modify the code, but he doesn't have the source code. I never used this brand of PLC/HMI before so I dont know if the PLC/HMI holds the source, or just the compiled .bin (or whatever they are).
The PLC is compiled codesys so you will have no luck with the machine.
the cable comes free with the software.
you will need codesys from schneider as the freedemo version stops after 1 hour in the plc.
After some interesting conversation regarding the safety of emergency stops, I saw some posts talking about the safety standard conversation...
26
960
I have programmed servos from a handful of variety of manufacturers and series. Each time I used a PLC without motion functions. I have not worked...
760
Hello, I'm am engineer for a plastic manufacturer. We swapped out a oem motor with one of equivalent nameplate stats made by marathon on our roll...
501
I am trying to implement a sfift-by-wire on a vehicle and for that I am using a standard servo motor...
331
Had an interesting experience this morning. An old Panelview 600, 2711-K6C5X series B to be precise, comes up as error 32. Unfortunately it...
220
