generate a pulse signal in structured text in Studio 5000
batindeko
Nov 2017
stutensee
Hey,
i need help to write a structured text program that set a signal to high 6s and to low 6s. I used TONR to do this but it doesn't work
Code:
TONR_0.PRE := 6000;
TONR_0.Reset := Reset ;
TONR_0.TimerEnable:= 1;
TONR(TONR_0);
timer_state := TONR_0.DN;
TONR_1.PRE := 6000;
TONR_1.TimerEnable:= timer_state;
TONR_1.Reset := Reset;
if timer_state then
TONR(TONR_1);
if  TONR_1.DN AND Local:1:I.Data.1 then
TONR(TONR_0);
end_if;
end_if;
		if TONR_0.DN then
			impact67_55144:O1.Data[0]:= -1;
			impact67_55144:O1.Data[1]:= -1;
		end_if;
		if not(TONR_1.DN) then
			impact67_55144:O1.Data[0]:= 0;
			impact67_55144:O1.Data[1]:= 0;
I wote the same program in ladder logic and that program works fine find attached the program here
Code:
[COLOR=Red][B]if timer_state then <-delete just this line[/B][/COLOR]
  TONR(TONR_1);
Try deleting the line in red.
Code:
TONR(TONR_1);
I finallly found how to do it. below is my Code.
I would like anyway to know which other method i can use to make it. thank again for your Support.
Code:
TONR_0.PRE := 1000;         // set the preset time
TONR_0.Reset := TONR_1.DN  ;    // reset the
TONR(TONR_0);
TONR_1.PRE := 1000;
TONR_1.TimerEnable:= TONR_0.DN;
TONR(TONR_1);
		if TONR_0.DN then
		else
		end_if;
This is with a IEC TON timer, as it has been a few years since I had to touch an A-B PLC.
Code:
myTON(IN:=NOT myTON.Q, PT:=t#6s);
bSignal := bSignal XOR myTON.Q;
There. Every time the timer elapses, it will flip the bSignal.
It's pretty crude and will start in the off state, but it's quick and easy.
Some translation:
.IN = .TimerEnable
.Q = .DN
.PT = .PRE
Does anyone know how to generate output pulse in plc CP1E-N40DR-A??? What instruction i need to make pulse output working.....
1,898
Hello Friends, I am looking for a way to take my PID Output( it is the result of my PI Algorithm in Real format) and generate a PWM Signal in...
2,511
Does anyone know a way to dynamically generate a 2D barcode on a PanelView screen? An Activex Control maybe? If such a method is out there, it...
2,988
Hi, I am trying to generate source file of OB1 including all dependent blocks. But i am getting a message which says-->>one or more blocks...
1,256
Hello Everyone, I would like to know where to start when designing a HMI+PLC Allen Bradley based, that complies with CFR 21 PART 11, ALCOA...
2,911
