100HP motor control options
I assume that the fan has a start-up throttle element ?
If so, any softstarter rated for the 100 hp will do.
Apart from that, even if the customer hasnt specced a VFD, you might suggest it if the dust collector is to run at less than 100% capacity.
And a tip: If you go for the VFD, you can omit the start-up throttle, and thereby reduce the extra expense for the VFD somewhat.
I had trouble for a week trying to get a Marathon Symax Motor autotuned to work with a Powerflex 753 drive. I solved the problem and thought I...
49
Hope you are doing well. Currently, I am involed in a revamping project. It requires to stop a mixer at specific postion. For the detail, this...
303
251
352
Hello, It is mandatory to use VFD IF i use IE5 electrical motor? What happens If connect it directly as delta without VFD? Please look at motor...
177
