100HP motor control options
I assume that the fan has a start-up throttle element ?
If so, any softstarter rated for the 100 hp will do.
Apart from that, even if the customer hasnt specced a VFD, you might suggest it if the dust collector is to run at less than 100% capacity.
And a tip: If you go for the VFD, you can omit the start-up throttle, and thereby reduce the extra expense for the VFD somewhat.
I'm looking for how others do it. I need to start a 1 phase motor. I have always used a regular 3 phase Motor Protected Circuit Breaker and looped...
I've got this 3-phase 575V motor that we're controlling with a VFD (Variable Frequency Drive), which has been quite the learning curve in itself...
293
Hello, It is mandatory to use VFD IF i use IE5 electrical motor? What happens If connect it directly as delta without VFD? Please look at motor...
150
Here's what happened, Operator turned on the disconnect for an auger while it was still running to cut power. Auger DID in fact turn off, but the...
352
Hello all, In my facility we have multiple 3HP 460V motors that are being controlled by VFDs which drive conveyor belts. The drives are randomly...
220
