Power Flex drive outputting wrong speed to user's plc
BTL_Man
Nov 2007
N.C.
Power Flex drive outputting wrong speed to user's plc.... HIM
is reading correct but 4-20 ouput is wrong.
The analog output usually can be scaled in the software. 20ma usually is the motor nameplate FLA but, on some drives, it is the drive current limit setting.
Better check out which it is.
I am trying motor startup with pf525 drive by using wizard start over ethernet communication but during direction test it's showing control error...
187
Hi I want to set IP 172.16.27.90 in AB Power Flex 755 drive. I do set the IP by parameters 38-41 with other settings (subnet, gateway) but...
2,465
I'm looking at how to configure a (new to me) Power Flex 753 drive. The part number is as follows and has been specified by a third party...
2,361
i have a problem in the drive 30 kw used with motor 4 pole (1770 rpm ) , and the motor used to run load with pulley ratio 2.3 so the load speed...
4,898
F005 fault appearing on power flex drive plz tell me how to reset
2,363
