TIA Portal hardware catalog in relation to F-DI / F-DO modules
kobelu_090
Aug 2014
UK
Hi guys ,
Since I'm not very familiar with the Siemens PLCs safety system I got a couple of questions which you could help me with:
Currently my engineering laptop has installed TIA Portal V13 SP1 .
When I go to the hardware catalog the only safety devices that I can find are :S7-300/400/1200/1500 F CPUs and the ET200S-Failsafe/ET200SP-Failsafe CPUs.
What I can't see are the F-DI/F-DO modules!
I know that on top of the existing software package(TIA Portal v13 SP1) I have to install the Step7 Safety Advanced v13 for programming the safety CPUs. Will this additional software enable the F-DI/F-DO modules in the hardware catalog as well?
Best regards
kobelu_090
Hi JRW,
Thanks.
So STEP 7 SAFETY ADVANCED V13 SP1 is the the only add-on software that I have to install in order to be able to see the F-DI/DO modules in the hardware catalog?
Regards
kobelu_090
If you haven't done it, I would recommend installing any HW support packs, as well. This will make sure you have all the latest HW in the catalog. HSP's can be installed from the TIA uploader thingy.
Hi mk42,
That's a good idea. Usually I do that , but in this case ,I believe the F-DI/DO HSPs will be available in TIA Updater after "Step7 Safety Advanced" is installed .
regards
kobelu_090
Hi mk42,
That's a good idea. Usually I do that , but in this case, I believe the F-DI/DO HSPs will be available in TIA Updater after "Step7 Safety Advanced" is installed .
regards
kobelu_090
Oh, yes, I didn't mean for the HSP to replace installing the safety software, that is almost definitely required.
Hi PLC people, think about this scenario: The PLC is somehow connected to the same network with the facilities` network. Then someone connects to...
140
Hello Folks, I am beginner to the PLC programming. I am working on a project which has Siemens S7-1516-3 PN/DP CPU, and ET200SP profibus based...
343
In RSLogix 5000, I can export the hardware config and import it to another controller... Is this allowed in TIA Portal V15.1? And if so where...
6,921
I am using TIA Portal 14 and I cannot download to 6AV2 124-0UC02-0AX1 which is a TP1900 Comfort as I do not have the Hardware file for the device...
2,376
I am trying to test my PLC program but I find the PLCSim of TIA portal insufficient: you can only run one sequence at a time. I am trying to test...
6,027
