export hardware config tia portal
dahnuguy
Mar 2007
SC
720
In RSLogix 5000, I can export the hardware config and import it to another controller...
Is this allowed in TIA Portal V15.1?
And if so where?
I am pretty sure I remember being able to export the hardware config in Step 7.
The answer is "kinda". I'm not sure how Rockwell does it's export. Because a Portal project can have multiple PLCs, HMIs, drives, etc, and each is a separate device, it may think about the data a bit differently.
There are a few options:
1) Copy/Paste from a reference project
You can open up an old project as a "Reference Project" which is essentially a Read Only project open in the same instance of Portal. You can grab all the IO devices in the HW config and copy to the new project, then assign them to your new controller(s).
2) Create a Library
If you have a HW setup you use all the time, you can drag the objects into a library. This keeps all HW parameters. You would need to reconnect them to the new PLC in the new project, if you don't want the PLC included with the rest of the IO.
3) Export/Import CAx data.
This is the one most similar to the old Simatic Manager function. It is compatible with the TIA Selection tool (great for building a quick BoM), as well as EPLAN, if you use that for ECAD. If you export CAx from Portal, it exports the part numbers and tags, but not PLC code. When you import, you have choices about how to handle potential naming overlaps (overwrite, keep old, rename new devices).
I made by CAx data export, but why HMI Panel was skipped?
If HMI Panel was skipped, maybe more device as well ?
PS. It is possible to export CAx data file pro CPU and not for whole project?
Is there a utility that can export the controllogix rack configured modules into csv or txt file ? aside from the print options.
1,516
Trying to export a Modern application for an upgrade to Intouch 2020 but I cannot export the application from the 2014 version because the export...
108
Hello, Does anyone know how to export the EDD files for a device in DeltaV Explorer 12.3? I can export the .fhx, but I have no idea how to get...
133
Hi, I'm trying to export data from a DataGrid to Excel using VBA, but I'm getting an error "Object doesn't support this property or method". The...
82
Hello to all, Is it possible to export Codesys symbols to .txt, .csv or .xml in a similar manner like exporting symbol table in STEP 7? For...
130
