Schneider HMIGXO5502 with different PLCs
fadiking2003
Sep 2017
turkey
Hello, i am trying to connect Schneider HMIGXO5502 HMI to a Delta PLC using rs232 or rs485.
I don't know if that is possible or no , or the HMI can be connected only to a specific types of PLCs ??
You should have no problem with that. Just configure your devices the same way. But it depends on what those devices offer for communication. You should also be able too use Modbus TCP/IP.
Everything was working fine, but suddenly CPU went into error mode, and the ERR and TER LEDs lit up. Now I can't download or connect with the PLC...
41
Hello all, I am wanting to update the system clock via NTP in the M580/M340. I'm aware that we are able to connect to a NTP in the controller...
131
I am using Schneider elau pack drive servo motor ISH-100. I am facing the problem that On the ISH -100 red light is blinking and pack drive C-600...
63
Hello, As part of our project, we are using an M241 controller. This controller interfaces with an industrial computer and a router via a switch...
106
Hello, I need to access the bits from the fire system control panel through RS-485. So, I used Read Var block to read from the panel...
187
