DISQ Won't clear Logix5572
ronv5300
Mar 2019
South Africa
Recently we had a process trip on compressors. When investigating I found three of six redundant pairs with DISQ status. Note these systems are in separate UCP's with redundant power, networks etc.
Fault finding included replacing the Fiber Links between redundancy Modules, and restarting controllers one by one, to ensure Primary is up when secondary is started. No success.
System has been online since 2016 and no recent hard or software changes were made?
Any ideas why I cannot clear the DISQ status?
That was my initial thought. Co-incidentally on this occasion a Gas Turbine Generator was started, one that is due for replacement on its bushes and this was checked for earthing issues. I tried using RSLinx to manually synchronize the Redundancy Modules, without any success. Shows offline. Logs cannot be exported due to non-availability of the second unit as well. Hardware replacement maybe?:confused:
Hi , i have problem to configure redundancy of two plc , i have set into both plc the redundancy function and now i have PLC 1 with PRIMARY and...
4,197
I have following issue if someone can help me with:- - have Redundant PLC with L64 controller - making any bulk edit online in primary controller...
1,237
Hi Guys, I've got a problem with two redundant ControlLogix PLCs using the redundancy modules and I am not very familiar with them. They were...
6,435
We have L61 redundant existing plc. when we add new en2t module after configuring it inside the logic, the secondary going DISQ. Please advise...
3,804
I have a managed InTouch Application that I deployed changes to through Archestra IDE yesterday. The only changes I made was adding a solenoid...
92
