WinCC Flexible and Protool
Garcia
Apr 2006
Pittem
37
Hello,
Is there someone who has experience with running WinCC flexible and Protool as plug-in for Simatic manager? All my previous projects are made in Protool but I want to change to WinCC flexible. Can I use both programs without having any conflicts?
thnx, Bert
Hello Garcia.
You can install Protool and Flexible on the same PC.
Only one of the two can be integrated into STEP7.
If I click on an integrated Protool project in STEP7, nothing happens. I have to navigate to it manually from within Protool. Apart from that it works without any problems.
Win CC Flexible opens correctly when I click on an integrated Win CC Flexible project.
You may well find that Protool will fail to start by clicking an application in S7 Mangler . This has been documented by Siemens , and there is no cure except to open Protool once on startup of windows.
hi all,I want to migrate a OP7 protool program to OP77B winCC flexible but no success.It is communicating to S5-115U PLC.
2,156
Hi, We have upgraded our laptop which includes Windows 11. It appears that WinCC flexible 2008 advanced does not support Windows 11. What...
315
Hello everyone I Have an Issue with the usage of recipes in Wincc Flexible 2008, I create the recipe to change the values in a fast way The...
119
Hi colleagues.We do data logging system.We want to record three temperatures under a certain condition. We prepared the project as follows. We do...
766
Hello to everyone. I change the value of a "PQW" with a button in Wincc flexible. The code of the button is defined as M102.0. Value reset...
4,614
