Effect of online change of K to J-Type thermocouple in 1769-L35E
IdealDan
May 2017
MA
480
Hi Friends,
A quick one please.
Can online changing of Thermocouple Type K to J (configuration change in 1769 IT6/A module) fault compactLogix 1769-L35E Processor.
I don't believe that it should cause a fault, I'm not 100% positive though. I would think that if it would definitely cause a fault, they would have it greyed out while online.
I'm Considering it, as we temporally replaced a K-Type with J-Type pending when ordered K-Type will arrive.
I'm sure that you know this already, but be sure and change all of the wiring too. The thermocouple extension wire from thermocouple element to the analog input must be the same type as the thermocouple element. Otherwise errors can arise if the temperature of the screw terminal on the AI module is differerent than the temperature where the element connects to the extension wire.
Yes bro, you are correct.
We decided to wait for the K-Type since it's already procured.
I also observed that a Temperature reading on the HMI (Panel View Plus) is not corresponding with what is displayed on the SCADA (VijeoCitect), difference of about 5 degree Celsius.
WHAT COULD CAUSE THIS PLEASE?
Thanks in advance.
Thanks in advance.
I am considering using a "magnetic cable tie mount" like this one: https://www.grainger.com/product/MAG-MATE-Magnet-with-Zip-Tie-Holder-49M018 It...
71
Hi everyone, I need a solution based on the cause and effect diagram, especially a macro sheet or VBA script in Excel, which will help me generate...
75
Possible dumb question here, but how does running a motor through a gearbox effect a VFDs ability to limit the torque on the driven load? My gut...
523
I made a small update to the PLC logic (GX developer). Then I wrote the updated code to the PLC (I did Online/write to PLC). I thought that would...
1,521
Hello guys, I need some help. I read all the old posts on hall effect sensors but none dealt with my module. The system uses a Gemco 194761 RFO...
1,720
