Wonderware Intouch to Compactlogix Application Question
agarb
May 2006
USA
309
I'll preface this by saying that I am an Intouch beginner…
I have an Allen-Bradley Compactlogix that currently stores recipes in an array[0-20] that is a UDT consisting of the elements something like this:
Recipe[x].Name (string)
Recipe[x].Editable (Boolean, where 0 = no, 1 = yes)
Recipe[x].Color (integer, where 1 = red, 2 = blue, etc)
Recipe[x].Length (real)
Recipe[x].Width (real)
... and so on...
With Intouch, I am trying to figure out how to create a single screen where the user can view/edit the contents of recipe[x] after they enter the recipe number, x.
So far, I’ve read the intouch help files about substitution of tag names, remote tag references, and indirect tags. It seems like indirect tags will sort of do what I need but it says indirect tags are only for integer and real types. Looks like my string and Boolean can’t be indirect.
Any suggestions to get me on the right path?
(I can modify the PLC if necessary but the Intouch application is being added to an existing, functional CompactLogix system so I want to be as non-intrusive as possible.)
Thanks!
The InTouch database has the following types: Indirect Discrete, Indirect Analog, and Indirect Message (String). I have used the discrete and analog but not the message but it does have that capability.
Hi guys, I have experience with PLC to Excel etc...just starting on using intouch scada screens. I have an Excel sheet that uses mainly...
143
Hola chicos. Tengo un problema con el driver de comucicacion dasabcip 5, y un plc controllogix v34, ya realice la comunicacion pero en ciertos...
157
Hi, I am upgrading a Wonderware SCADA form version 9.5 to version 23. I am able to migrate all the graphic, but when to activate the runtime this...
409
Hi all, I am using OI.GATEWAY.2 to communicate to the PLC using an OPC UA. I can see the tags using an OPC explorer connecting to the...
183
For a while, I have been working with InTouch 10.1. The problem I am currently facing is the need to implement certain functions that do not...
480
